Screen randomly goes white after replacement
Hi, trying to fix my son's iPod touch 4 after he dropped it, smashing the touchscreen and denting the case.
I put everything into a new case, and fitted a new LCD and touchscreen unit. I tested without putting adhesive on in case I needed to do anything.
It worked for 10 minutes then screen brightened to white and ipod was unresponsive so I held power button until it turned off. It wouldn't turn back on and wasn't recognised in iTunes.
I had to let the battery go flat over several days, then plugging it into the charger brought up the charging symbol.
It worked for 2 days then while being used went white again. Won't come on again now so I'm leaving it to go flat again.
Has anyone had this odd random screen issue after a screen replacement? I don't know what to do next...
Thanks
Esta é uma boa pergunta?
2 comentários
Thanks for the reply. While it worked for those 2 days, I noticed the battery went flat in only an hour or so of use. No shorts so will try a new battery and post results here.
por Chappers
I did wonder if it might be because the screen is a copy. As for the copper tape, I don't recall any being on either of the two screen connectors. Which should have it, the uppermost connector visible when screen is lifted, or the one hidden under the logic board?
por Chappers
