Ir para o conteúdo principal
iPhone 5 Battery Drain when Off.
Hi, My iPhone 5 has a serious problem, When the phone is powered on the battery give me about 5 hours only, but the problem is when I turn Off the phone, The battery keep discharging until it can't power on the device again, I tried every solution, Restore new firmware, Change the battery, The charger .... but nothing....
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
2 respostas
Solução escolhida
This is a common problem with the iPhone 5 it's most likely the power ic U2 chip ..
It's can be caused by using 3rd party chargers
Esta resposta foi útil?
Pontuação 1
My iphone 5 drained very fast once I installed a new app, even though I removed the app, the battery still drained fast. I had to charge twice a day. Then I searched on reddit, they suggest me to calibrate the battery, now my phone work normal again.
Pontuação 0
Adicionar a sua resposta
cranknet será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,896
