stuck on battery charging sign not booting into the OS
Hi Everyone!.
So i bought a retina macbook pro 13'' late 2013, the person said it had liquid damage and apple said that it would need the following things to get it working again
Display clamshell
top case
logic board
SSD
I bought it because i got it a bit cheap
so i took out the logic board and the ssd and cleaned it, SSD is fine, it works in my air, the LVDS connector on the board and the lcd was burned pretty bad, i replaced the whole lcd with a spare one i had, (has a little crack, i use it for testing), i wasn't expecting it to work but even with the burned LVDS connector ,the lcd lid up to the battery sign, i was very surprised.
The liquid damage was in the lcd connector area only not through out the logic board**
OK, so the problem I'm facing now, is that the macbook only shows the battery sign when i plug in the charger, it doesn't charge the battery and doesn't have any light on the magsafe, so its stuck on the battery sign.
Any suggestions how i can fix this?, I'm good at soldering, i don't want to replace the board as its very expensive.
Thanks
Esta é uma boa pergunta?
