Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Where is the Wifi Antenna on a 5C?
I recently repaired a 5C, doing my first screen replacement on one of these models. Replaced the screen and LCD assembly completely, bringing over the old home button, camera, earpiece, etc.
Now I have no wifi. The wifi is greyed out in the menu, and won't turn on. I believe I accidentally bumped the wifi antenna, but I don't have a clue- where is it?
Esta é uma boa pergunta?
Pontuação 6
1 comentário
I can't see the Ici but ICI see the imei is and my Bluetooth don't work along with my phone saying not service
por
Adicionar um comentário
2 respostas
Solução escolhida
This is the wifi anntena here and it plugs in under the motherboard if you only changed the display then you would not even be close til this part .
I would try a restore first to rule out a a bug in the system if it's still greyed out after then you have damaged the motherboard in someway
Esta resposta foi útil?
Pontuação 3
Sounds like somehow the wifi / Bluetooth IC chip got shorted.
Most likely when doing a screen replacement without battery plugged in.
Most likely your Bluetooth does not work as well.
Pontuação 2
Adicionar a sua resposta
Ian Dalsin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 6,916
