Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Pergunta encerrada
Cannot reset SMC, battery not charging to 100%
I got the battery replaced in my 13" MBP probably about a year ago, and now again it's showing some of the same symptoms.
If I unplug the magsafe power adapter, and plug it back in, no light comes on at all. So I'll try to perform SMC reset - and absolutely nothing happens. I mean that nothing happens when I try to reset the SMC - it just won't go through.
The only way I can get the light to turn back on on the adapter is to take the back off, and disconnect the little ribbon that is plugged in. After about 5 seconds, the light comes on and I'm fine as long as i keep it plugged in.
Also the battery will not charge to 100%, just stays at 90.
Here is some info:
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro5,5
Processor Name: Intel Core 2 Duo
Processor Speed: 2.53 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache: 3 MB
Memory: 8 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP55.00AC.B03
SMC Version (system): 1.47f2
Serial Number (system): W89428J066E
Hardware UUID: AB8F6457-929C-5FAE-BCED-9541CCCFC409
Sudden Motion Sensor:
State: Enabled
Battery Information:
Model Information:
Serial Number: W02314AKVD3LC
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 201
Hardware Revision: 000a
Cell Revision: 165
Charge Information:
Charge Remaining (mAh): 3987
Fully Charged: No
Charging: Yes
Full Charge Capacity (mAh): 4440
Health Information:
Cycle Count: 191
Condition: Normal
Battery Installed: Yes
Amperage (mA): 1381
Voltage (mV): 12520
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Nothing will outwardly happen when the SMC is reset correctly. Here's how to do it correctly:
http://support.apple.com/kb/HT3964
Esta resposta foi útil?
Pontuação 0
4 comentários:
I've had to reset the SMC before and this "Note: The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC." always happened. It hasn't happened any of these times and isn't fixing the problem.
por
Run Coconut Battery and let us know your results. Is this an Apple Battery or a knockoff? http://www.coconut-flavour.com
por
If it's knockoff I'll be very angry - I got it replaced at the Mac Store not too long ago. Long enough that the extra year warranty has already ceased.
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 3,295
