Ir para o conteúdo principal
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Perguntas Visualizar todos
Upgrade I/O board USB 2.0 to USB 3.0
Hi friends,
My name is Fábio and I would like upgrade the I/O board USB 2.0 to USB 3.0. Is it possible?
My computers is a "MacBook Air 11" Mid 2011".
The actual board 2.0 is working well.
Regrads,
Fábio - Brazil.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
"Belkin Thunderbolt Express Dock" as an external solution should work. But it is a $200 solution so i think a new laptop is a better idea.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Sadly the I/O board does not hold the USB controller chip. That function is part of the Intel platform controller hub chip which is on the main logic board. The chip you see on it is the audio codec.
Pontuação 1
3 comentários:
Thank you. I understood. Is there something that can be done to upgrade the system to USB 3.0?
por
Sadly no. All laptops use a unitized controller chip these days that services all of the CPU's I/O needs. This chip is part of the main system board and is not replaceable (soldered). If USB 3 is that important I would recommend you look at buying a newer system and selling your current system.
por
Actually it is possible with external solution. I found this product. "Belkin Thunderbolt Express Dock".
por
Thanks everybody,
I think that exchange the currently system is the best option.
Best regards,
Fábio.
Pontuação 0
Adicionar a sua resposta
fabiohfs será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,856
