Ir para o conteúdo principal
Repair guides for the Magic Trackpad. Released in 2010.
How can I put power button back in place?
The batteries inside my magic trackpad suddenly exploded and power button throwed out !
Batteries were duracell non chargable
Anyway, there are these wires that have been cut and hanging both from inside the battery tube and the button
I think if i can connect the wires it can work again
But it's unreachable by hand and too small, also wires are too short
What can i do?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I dismantled the board and everything , i just need to know what kind of core (wire) to use for the connection between board and power connector/LED status .
por
Adicionar um comentário
1 resposta
Solução escolhida
Here's my previous answer on this problem, see if it helps: How to fix power button after a fall?
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Hadi Motamedi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 492
