Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
iPhone 4S Only powers on with cable after battery replacement.
Hi there, I have an iphone 4S which I was having issues with the iTunes error 21 which indicates that the battery is faulty.
After replacing the battery with a new one and other working 4S batteries the phone still does not power on unless its plugged in.
Even still, I am unable to use the phone as im not able to restore it.
Ive inspected the board and cant find any signs of blown caps.
I have also replaced the dock connector to rule that out.
Anything else i have missed to get this issue resolved?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If you have used known battery's and it still doesn't power up it could be that the solder has broken on the battery connecter on the motherboard
Esta resposta foi útil?
Pontuação 0
2 comentários:
Ive checked out the solder joins and there all making contacts. Confirmed this with a multimeter. I have found that there could be a cap somewhere on the board that is damaged. Read online that if the outside 2 terminals are making a circuit then it could be a cap gone. Will test this tonight.
por
This was put in to the too hard basket. Using the phone for parts now!
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 62
