Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
Home button is stuck and will not press down to work!
I have the same problem but it's with a iPod 4th Generation. Can that be fixed? Like, I don't want to open it apart or else I might wreck it. Are there any other way? I am currently using the Assistive Touch but I want to use the home button! I heard that if you use the A.T, your device gets more "laggier". So please anyone help me ASAP!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
There are no quick permanent fixes. If your leery about working on your device, an iPhone/iPod tech can pop open the screen and check the power button assembly and replace it, and/or the power flex cable (on the iPod 4th if the flex cable needs to be replaced it requires soldering).
Esta resposta foi útil?
Pontuação 2
Hello the home button does not require soldering it's easily replaced only problem would be opening it as it's glued down and needs heated up and pryed off..
I would get a shop to do it as you don't want to risk breaking the screen aswel
Pontuação 1
Adicionar a sua resposta
Akhan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 124
