Ir para o conteúdo principal
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Perguntas Visualizar todos
Adhesive for reapplying foot bumper on Toshiba Satellite U925t?
Hi. I had to have my screen replaced on this convertible tablet after the touch function stopped working. I shipped it off to Toshiba and since I've received it back, the front foot bumper strip that covers the screw holes keeps falling off. It appears that there is an adhesive strip under the bumper that holds it in place. Can anyone tell me the best way to fix this. I've considered just super gluing it, but I don't want to make it such that the screws can't be accessed in the future. I'm afraid to use the adhesive strips recommended for replacing screens because they seem to need to be heated and I'm afraid that I'd ruin the rubber bumper if I have to heat it to loosen adhesive beneath.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
the double sided adhesive for screen repairs will work. you should be able to pry off the bumper with no problem. a small piece of packing tape, folded over to create a double stick piece is an alternative.
Esta resposta foi útil?
Pontuação 3
1 comentário:
the real reason you need heat for screens is to prevent the glass from crackig.
por
Adicionar a sua resposta
Jon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 232
