Ir para o conteúdo principal
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
Why is my computer not recognizing iPod 1st Gen Nano?
I recently bought a used iPod nano 1st gen. I hooked it up via usb cable to my computer, it charges fine but it is not recognized by my computers USB removable hardware. I have 4th GEN nano that works fine the same USB cable. I tried resetting the 1st GEN nano and it doesn't solve the problem. What could it be?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
maybe its formatted to MAC and you have a PC. Set the iPod into Disk Mode and then restore it via iTunes.
How to set the iPod into Disk Mode can be found here:
http://www.command-tab.com/2006/03/30/hi...
The combinations of the 5th Gen iPod should work for the nano too. If not, let us know and we will search for the right combination.
Esta resposta foi útil?
Pontuação 0
same issue, except I can’t use disk mode at all. can still use radio remote and listen to the 96 songs i’m now stuck with
Pontuação 0
Adicionar a sua resposta
Mindy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 9,270
