Ir para o conteúdo principal
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
Why is my wifi not working?
I have recently upgraded my wireless module. After restarting my computer i have been unable to connect to my local wifi. I have checked my wifi on other devices and it works perfectly, so i assume its a problem with my computer.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
First things first, check to make sure that your new wireless chip was correctly installed. If all pins and cables are correctly hooked up, then it may be a problem with your computer's drivers. The new wireless chip may not be able to communicate correctly with your computer due to out dated WLAN drivers. HP provides WLAN drivers on the HP 200-2d22DX support page found here. Make sure to install the correct driver for your wireless chip's manufacturer!
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Yojar Paz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Ao todo: 1,258
