Ir para o conteúdo principal
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Perguntas Visualizar todos
Need help removing the front screen
I am trying to change out my power supply, and am having trouble on Step 3 (releasing the front bezel). I am using my driver's license, inserting it in the air vent as pictured, but I never feel or hear a latch release. I have tried using a couple of layers of duct tape as well, but to no avail.
Any hints to releasing the latch??
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
I use a thick sheet of plastic (a driving license is just fine, but i'd use something more disposable) and bent the last 3cm to approx. 15 degree. Sometimes the catches on the bezel are bent or becoming loose so it helps loosening the bezel from the bottom and peek from underneath. Difficult to explain. Mail me (info@re.mac.de) and i'll send a few pictures.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I'd like to see your pics, but your email bounced back. Email me at miguk1 at mac dot com.
por
Thanks for the advice...I finally got it loosened.
por
Adicionar a sua resposta
David Etter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 642
