Ir para o conteúdo principal
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 Perguntas Visualizar todos
MacBook air battery 0%
Hi,
I'm having a weird issue here with the macbook air. First I thought the battery was dead so I purchased a new one. After replacing it: no charging, the magsafe light green, 0% on the battery icon. If I unplug the adapter -> sleep mode. I plug back the adapter, it wakes up but still 0% forever...
I tried (without success) pram and smc reset.
I also opened the rear case, plugged the adapter, power on, disconnect the battery while still powered, reconnect the battery and tada! Displaying 88% battery, everything seems normal, no sleep mode if I unplug the adapter, I thought the problem was solved. But if I shutdown and unplug/replug the adapter, I'm having the 0% battery issue again.
I cannot start the macbook without the magsafe adapter plugged. But I found another "trick": I plug the adapter, press the power button and unplug immediately the adapter. It boots, displaying 0% but still without going to sleep mode.
What the ****'s going on?
EDIT
Problem solved. I did the trick with unplug/replug while still powered and let it charge a whole day. Then everything came back normal.
I'm not a specialist but it sounds like something needed to "charge" apart from the battery.
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Hi jpfroud, thanks for the EDIT on your message. I have the same issue unfortunately and no forum out there has been helpful. However you seem to have done something but I can't seem to understand your trick. Could you detail it a bit more? That would great if you could !
Thanks in advance
Damien
por
@Damien Busson
Sorry, can’t remember, it’s too old
por
Adicionar um comentário
1 resposta
Solução escolhida
RUN AHT and see what it says.
My vote is for a bad SMC chip. If so, this would not be a beginner DIY project. If you have lots of experience with soldering small electronic or computer components your qualified, if not - this is not the place to start.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 2
1 comentário:
por
Adicionar a sua resposta
jpfroud será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 3,161
