Ir para o conteúdo principal
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
76 Perguntas Visualizar todos
Pergunta encerrada
Can I use this memory to upgrade the MacMini?
Here is the link to the memory I want to buy:
http://www.newegg.com/Product/Product.as...
It looks like it should work but I am concerned that it won't because it has a higher speed rating. Shouldn't it just run at the lower speed rating that the machine is capable of?
MacMini4,1 currently 4GB, 2.4GHz Running Mavericks and up to date EFI.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Your box supports 1066 MHz PC3-8500 DDR3 SO-DIMMs. So theoretically it would work... but the brand name is unknown, e.g. not top tier. Crucial, Kingston, PNY.
Sometimes it 's the tightwad that ends up spending the most $... for ~20$ I'd go top tier.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
The mid-2010 Mac mini officially supports up to 8GB of DDR3-1066 RAM; but it does run 16GB DDR3-1066's -- it doesn't, however, support higher clock speed modules.
As far as G.Skill as a brand is concerned: they aren't "unknown". They have a solid reputation for performance products. Sure they don't have in-house memory IC's (ie: Crucial/Micron, Kingston, Samsung, etc), but they are hardly considered an "unknown" brand. But I digress...
OWC offers 16GB DDR3-1066's that work in the Macmini4,1's at a $50 premium (http://eshop.macsales.com/item/Other%20W...).
My set are using SK Hynix H5TQ8G83AMR-PBC. Judging from SK Hynix's product coding convention, that "PBC" part indicates it's a DDR3-1600 @ 11-11-11 timings; however, the modules are apparently clocked as DDR3-1066 @ 7-7-7 timings.
Pontuação 3
1 comentário:
Very Knowledgeable and Helpful Thank you very much
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 1,729
