Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2201 Perguntas Visualizar todos
Front camera clear plastic ring alignment issue?
I am having an issue installing the front display on the iPhone 4S.
The front camera has a clear plastic ring piece and I am not able to get the alignment right to sit over top the front camera housing cleanly.
Any suggestions?
Thanks.
Andre.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Put the plastic ring over the camera don't stick it to the screen it should fit nicely into place over camera
Esta resposta foi útil?
Pontuação 0
2 comentários:
I'm tempted to remove the ring from the new display and use the old one which I know fits.
por
Yes take the one off your new display be careful not to scratch the glass
por
My problem is similar except the ring seems to not sit flush but is raised above the surrounding structures and therefore puts pressure against the rear glass with potential to break it
Pontuação 0
Adicionar a sua resposta
andre será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 700
