Ir para o conteúdo principal
The fourth Google Nexus smartphone, released November 13, 2012.
75 Perguntas Visualizar todos
Micro USB port damaged
Plugged phone in last night, noticed intense heating around charging port and lead. After testing that the chord was fine, I saw some rust/copper looking metal at the bottom of my micro usb port. No matter what I have done, the phone will not recognise charging cable. Do I need to replace the charging port, or is there some other solution?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you try the other USB cable? If you tried but still failed, you may need to replace the charging port.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Luke Burke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 356
