Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
Is it possible to clean under individual key?
For some reason, my recently bought MacBook Pro 13" retina has a sticky Enter key. I have absolutely no idea why, but I'm worried that if I take it to the Apple store (despite the warranty) they'll claim that I've spilled something into it. So I was wondering, since only the Enter key is affected, is it possible to remove only this one key (without opening up the entire computer) and clean under the key - maybe with alcohol - safely?
Many thanks,
Florian
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Yes, you can take off the key cap and its possible the wire actuator has slipped (causing it to not spring back).
If you spilled something then I would recommend using a cotton swab (Q-Tip) slightly moistened with distilled water to clean the area. Make sure you don't over wet the swab as you don't want the water to drip in. You can also give the area a second wipe with a good grade of Isopropyl alcohol to clean any oily deposits and to speedup the drying.
Here's a good vid: How to remove and clean Macbook Pro keyboard keys
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks so much!
por
Thank you, it's very helpful
por
Adicionar a sua resposta
schumanntf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 37,567
