Ir para o conteúdo principal
Tudo que você precisa para reparar por conta própria o seu iPhone! A iFixit tem guias de reparo gratuitos e informações de desmontagem para cada um dos modelos iPhone, assim como as melhores peças de reposição e ferramentas da galáxia!
36478 Perguntas Visualizar todos
Why is screen freezing in an enlarged state?
My main screen is freezing and it has somehow enlarged to almost 5 or 6 times it's size. I have turned it completely off and it comes back on looking normal for a second, and then returns to the enlarged state and it is completely frozen.
Esta é uma boa pergunta?
Pontuação 17
4 comentários
thank you so much for this good and bright question
por
find my iphone
por
Never would have believed the answer so simple. Thank you!
por
Thank You so much just saved cust time going to apple store
por
Adicionar um comentário
13 respostas
Solução escolhida
Try this.
Double tap the screen with three fingers simultaneously and it should go back to normal. Three finger tap is zoom functionality of iPhone 3G-S added feature
Guide
Page 189 - Zoom
Turn Zoom on or off:
In Settings, choose General > Accessibility > Zoom and tap the Zoom On/Off switch.
HIH
Esta resposta foi útil?
Pontuação 42
22 comentários:
The frozen status was happening to my phone too often. I stopped in Best Buy and asked them but, they had never heard of it. I read your answer and just tried it. I must say it worked!!! I love my iPhone and now I know what to do when it happens again.
Thanks for your help.
por
Thank you! I was going crazy not able to figure out what was wrong, everything was frozen, and jumping around whenever I tapped the screen, and thought I'd have to go to the Apple Store, where there is always a long line!
Why does this happen to the phone? The 3 finger tap worked for me!
por
Oh my goodness, thank you for this answer. The blown up screen thing happened to me in the airport and I asked several and none of them had ever experienced it before. Thank you for your solution. Where do you find the answers for these weirdnesses that happen with iPhones and what is it that I am doing to it to make it happen?
por
OH my god!! You really saved me from the !&&* i was going through!! I thought of smashing the phone as it drove me crazy!! above to it i had to face this problem while i was at sea with low internet facilities.. U made my thing work again like it was!! Oh i really thank you for this answer bro!!... Cheeers .. turned off the zoom too!! love my iphone again :)
por
You are my hero! My screen all of a sudden became enlarged and I couldn't make a call, answer a call, turn off my phone or use it in any way. I've done it several times and had other people to try to fix it but I can't understand what I keep doing to make it enlarge. I tried the quick double tap of three fingers and it worked. I am forever in your debt.
por
Exibir mais 17 comentários
Thank you, and so easy. I was going crazy trying to figure out what to do. Great fix!
Pontuação 6
4 comentários:
Not working for me!!
por
Not working for me also. Any more suggestions
por
Not working. What did I do wrong?
por
Try tapping 3 times with 3 fingers if tapping twice doesn't work. That's what worked for me
por
This is perhaps the most stupidly conceived and poorly executed feature of the phone. Apple fails on this one. A big fat F. F for not anticipating that nearly every user who accidentally drags a lazy finger across the display and inadvertently triggers the blow-up mode will naturally assume that his or her phone has gone haywire and is frozen in some weird freak-out state of malfunction.
We have all had experiences with displays that are unable to interpret input signals properly and as a result they show us stretched images, shrunken images, images that are distorted vertically or horizontally. Is it any surprise that when you unknowingly trigger this massive zoom in, which results in a screen which becomes no longer responsive to the touch control you are used to, you freak out and think your phone is frozen? NO.
Apple, you get a lot of things just right. But you SUCK on this one. What happened. Was it Friday afternoon on a holiday weekend when you came up with this? Unbelievable.
Pontuação 4
1 comentário:
Absolutely LOVE this comment!!
por
Yep three finger tap worked for me too also turned the zoom off in settings .
Pontuação 3
Oh, my goodness! This has been happening to me for three years - I'm older so just thought is was my ignorance. Tried this and it worked first time. Thank you so much!!!
Pontuação 2
Thank you for the easy fix!!! I've had my phone for two years and the zoom/freeze has happened so many times that I was ready to throw my phone out the window! I can't believe the solution was so easy! THANK YOU!!! :)
Pontuação 2
I too was going crazy about this hidden surprise function. Thank you for the very easy fix. I guess I should read the manual.
Pontuação 1
for 3 years I thought I was the only one this ever happened to--Thanks
(though now that i know how to fix it it will probably never happen again)
Pontuação 1
I had to restore my phone and load from backup.
Pontuação 0
Tried tapping with 3 fingers & it almost worked, however we have a blank screen & are not able to turn off? Help-4S!!!!
Pontuação 0
1 comentário:
You have to tap SEVERAL TIMES WITH THREE FINGERS. :-) I also tryed the once with three fingers as i was scared to death i would blow it up to never never land. But the second time this happened I reread how to do this and sure enough it said tap several times with the three fingers and that was the trick!! It worked perfectly!!
por
I was in panic mode......3finger tapped worked. I turned zoom off in setting!!
Thank u so much
Pontuação 0
I cannot believe this actually worked. I had been tapping like crazy while in my hand. I finally place it on a firm surface and presto it returned back to normal . I immediately turned off zoom. Thank you , thank you
Pontuação 0
I think I changed the font size accidentally in the phone itself and the three finger tap is not working for me. I can’t even turn it off to see if it will reset. Also my mac doesn’t recognize it, so I can’t back it up, The home font is so large that I can see 1 to enter my password, half of 4 and half of 2. How in the heck can I get out of this? Thanks in advance! I have an iPhone 7 plus.
Pontuação 0
Adicionar a sua resposta
Rebecca Williams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Duração total: 61,372
