Ir para o conteúdo principal
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Perguntas Visualizar todos
Upgrade motherboard feasible with later model A1181
I have an old 2006 black macbook 13" that has a core duo processor which can't go any higher than 10.6.8. I am maxed out on OS options with this device.
Is a 2009 macbook motherboard compatible with my computer so to be able to upgrade my old macbook?
Thanks!
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Apple MacBook "Core Duo" 2.0 13" (Black) Specs
Identifiers: MacBook - MA472LL/A - MacBook1,1 - A1181 - 2092
por
Adicionar um comentário
1 resposta
Solução escolhida
You may be able to go to the 2.4 Ghz 661-4709 without a problem.
Esta resposta foi útil?
Pontuação 1
3 comentários:
How likely do you think that, that motherboard will be compatible with my laptop? Do you have any references or is it maybe personal experience?
por
You look in the parts catalogue for compatible parts... generally as long as you stay in the model year they fit. Where you have problems is trying to jump years... screw holes and other ports just don't line up.
por
Click on the "solutions" tab and do a search for "upgrades", then try "logic". You will find the previous questions on this issue.
por
Adicionar a sua resposta
Ian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 280
