Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
iPhone 4s LED flash problem
Hello everyone. I hope this is the right place to ask. Because I don't really know it is a software problem or a hardware problem.
I have a problem with my iPhone 4s LED flash. When I take a picture with the flash turned on, the picture become blueish or something like that. I think the problem occurred after I updated the iOS from 6.x to 7.
Can anyone identify the problem and solution to fix the problem?
Thank you.
Sample :
Sorry for my bad English. I hope everyone understand my question. :D
Esta é uma boa pergunta?
Pontuação 1
1 comentário
cant understand if the picture you took is a test shot to test the camera or to show us your phone. cause that's not a 4S. please specify.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
This type of issue is often just interference with the flash, either from a case, a screen protector, or some other cause (such as a finger too close to the flash). I don't know of any specific issues with flash between iOS6 --> iOS7. Have you already tried taking a picture without your case on to see if you have the same effect? Or perhaps a bit of plastic from a screen protector is too close to the flash? Sorry if this isn't your particular problem, but those seem to be the most common causes for this.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Warnerin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 1,159
