Ir para o conteúdo principal
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Perguntas Visualizar todos
I replaced my S4 LCD Screen, how do I get the sound working again?
I cracked my Lcd and had to order a new one. installed it, now I have no sound. Is there any way of fixing it?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I have the same problem, did you figure out any solution?
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Solutions for loudspeaker for Galaxy S4 I9505 no sound problem(from http://www.witrigs.com/replacement-parts...)
When external speaker for Galaxy S4 I9505 is broken, your phone doesn’t ring, sound notified or plays music/videos out. But if you plug the headphones in, everything comes back again. Bringing such a huge annoyance, it is speaker for Galaxy S4 not working that becomes a must solve problem.
Step 1. Check the setting
Go into the settings > sound > volume, make sure you didn’t turn on the vibration or silent switch, adjust the volume for music, ringtones and notifications, and then to hear if the Galaxy S4 no sound still.
Step 2. Reboot the phone
Hold on the power button and choose the restart option, hopefully do like this will eliminate any glitches causing the problem.
Step 3. Update software
For those who have not update OS, it will be a nice try. For others, you can find other ways to solve the problem of Galaxy S4 no sound.
Step 4. Replace loudspeaker
If all above the steps are failed, what you should consider is hardware problem and to replace a new speaker enclosure. If the trouble that speaker for Galaxy S4 not working still exists, send it to the repair center for checking the logic board.
Also, you should make sure if your USB board is installed well, because the loudspeaker is connected with it by two spring chips.
Esta resposta foi útil?
Pontuação 1
1 comentário:
None of those things worked for me so I downloaded an equalizer app and that fixed my problem.
por
I also had a similar issue. After completing the screen repair the in-call audio is diverted to bluetooth even when the bluetooth is turned off. Connecting to a bluetooth device is the only way to hear anything, incoming or outgoing. I'm more than certain it's not a hardware issue. Might either of you have an idea that may help?
Pontuação 0
1 comentário:
por
I have a samsung s4 and i cant hear the sound or music it has interior screen damage what can i do to make it work
Pontuação 0
i faced the same problem.my connection of the loudspeaker was loose .i tried to fix that.and it worked
Pontuação 0
Take off the back cover, unscrew the 4 bottom screws.
Gently pry the gray bottom that has the silver speaker on it.
blow on the inside of the phone, blow on the inside of the casing you removed
Click the casing back making sure all the connections are tight, make sure
You screw it in tight but not too tight.
That should work
If not get a replacement part for the part piece with the silver speaker
Pontuação 0
Adicionar a sua resposta
Vince será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 8,553
