Can I upgrade the speaker in my iPhone?
I would love to get higher quality sound from my iPhone 3GS. Is there a way to do this without having to use a separate set of speakers?
Esta pergunta é pertinente?
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
Yes, it can be done. It would take quite a load of work to first find the correct speakers with similar dimensions and then dismantle the iphone and replace it and making sure that it works! You're better off just using external speakers or a dock! The quality difference would be too small to actually bother.
It'd be very difficult to replace the speaker assembly in an iPhone, but that's not to say it can't be done if the right replacement parts were available: the latter is a question for the awesome iFixit team =).
The internal speaker is based on a plastic chamber located at the back of it improving the sound quality. If you change only the speaker,without any change of the chamber, the result may be no mentional.Redesigning the chamber is out of a common customer's ability and will, as well as the result doesn't worth the effort.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 30,171
