Ir para o conteúdo principal
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
How to replace the digitizer?
I read the guide and watched a few youtube videos, but when I tried to replace a cracked iPod nano 7g digitizer I couldn't get the LCD out. I ended up breaking the thin metal frame around it and scratching it, as well as bending it. I successfully removed the digitizer. How do you get the entire display assembly out? Also, will an iOpener help me remove the small back piece (above bluetooth antenna), as I had trouble with this as well? Thank you.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
The iOpener should help. Make sure that the spudger is under the entire display assembly to prevent bending the metal midframe.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
JT7 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 469
