How do I change the MAF (mas air flo) sensor?
Does the 2001 Honda Accord have a MAF and where is it and how do I clean or change it?
Esta é uma boa pergunta?
that depends on the used engine. the 4 cyl. has a MAF and the 6 cly. has a MAP sensor
maybe this helps you (the engines are not always changed after a modelchange): http://www.driveaccord.net/forums/showth...
Esta resposta foi útil?
2.3 accord does not have a MAFS, it works of the MAP sensor.
works off of MAP sensor, has no MAFS.
thx
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 47
Duração total: 17,110
1 comentário
Seriously? Are you sure it is bad? There will only be tiny bits of carbon in it. Why do you think you want to clean it?
por Dave
