Ir para o conteúdo principal
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
62 Perguntas Visualizar todos
CD stuck inside the unit. Help?
I have a mac mini as listed A1103 it belongs to my girl theres a cd inside the unit and it doesnt come out and seems to be causing some kind of error because the unit doesnt post. Is the cd inside causing the problem, in any case this is the issue how do i take the cd out?
Or do i have to replace the optical drive?
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
Restart holding down the mouse button and it should eject.
Also try:
Open the Terminal in the /Applications/Utilities/ folder and run:
drutil eject
Esta resposta foi útil?
Pontuação 2
2 comentários:
thanx let me try that now! im not very talented with macs. I work for HP maybe thats the answer but thanks!! another quick question..that is causing the problem of being unable to start up?
por
Let's get the CD out and see what it looks like. The unit may boot fine. If not let us know and we'll diagnose further.
por
If your CD is stuck and none of the other methods work, you might eventually try pulling out your optical drive and doing this: Optical Drive Disc Removal Technique
Pontuação 1
You could also try the
double sticky tape trick,
There's many reasons to fail POST however AFAIK a stuck CD is not one of them.
Pontuação 0
Adicionar a sua resposta
Ramon Aviles será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 3,415
