Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Can't separate the 2 tubs?
Trying to replace the center post gasket , removed center nut ,springs & brackets , hoses ,etc. I can't lift out the inner tub ,I've lubed it ,tap it ,hit it,cursed it,pried on it,almost ready to call a repair man (as my wife keeps suggesting) any help ?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Rod sorry for the delayed response, I believe I have a video to help you out with your issue. If you view the link here:
http://www.youtube.com/watch?v=0rwLLp8ND...
you should be able to successfully change out your center post gasket. If you need any further assistance please ask
~Gadget~
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rod será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 463
