Ir para o conteúdo principal
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Perguntas Visualizar todos
Is the battery between 2415 and 2560 ipad 2 any different?
I read that the ipad 2 2560 has a different internal construction. I was wondering if this meant the battery between the 2011 model and the 2012 model had changed. I do repair for my school's ipad program, and was wondering if I need to buy different battery types for different ipad models.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
They left the battery alone. You will use the same battery in each version of the device.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Steve Matousek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 317
