Ir para o conteúdo principal
Repair guides and support for Digital SLR cameras by Nikon from the high-end professional range to the entry level consumer cameras.
How do I replace the SD card reader on Nikon D5000?
When putting in an SD card, it does not engage and remain in the slot but springs back out. I can see a blue piece of plastic at the bottom of the slot which i cannot remove. it is suspiciously the same colour as an SD card and I suspect a piece has come off and lodged in preventing it from locking in.
Camera repair company say that the blue plastic is something from within the camera but looking at the D5100 stripdown page, there is no blue plastic in sight. They advise that it needs a new card reader and have quoted close to $200 for the job. I'm sure I am being ripped and would like to know how much to expect for a card reader replacement. I am happy to pay for a repair so if you can recommend anyone in London, England, let me know.
thanks
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
$200 for labor & part is about right to replace the assembly (the part alone is about $70) if you got it repaired here in the states.
Esta resposta foi útil?
Pontuação 2
2 comentários:
what if you do not see any debri in the slot but sd card will still not stay in the slot?
por
Same answer! You need a new SD port assembly installed in your camera.
por
Adicionar a sua resposta
aaron será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 1,591
