Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1502 Perguntas Visualizar todos
White screen when put to sleep
After replacing the vibrate motor in my iPhone it has a white screen when woken up from sleep, the only way around it is to reboot. ( Home button + Power button ) I've tried everything from restoring it,
( both in DFU and normal )
and all kinds of button combinations.
Removing the mainboard for an hour.
The phone works normal, if I set the auto lock to never. I've read that it could mean a bad LCD, but why would it show a white screen after locked but work normally when not locked ? Could it be because I didn't turn the device off when unplugging the display ? ( The screen was off though when I did it.)
All the cables are connected properly.
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Bump........
por
Replaced LCD and iphone is working again.
por
Adicionar um comentário
3 respostas
Solução escolhida
This problem is due to faulty LCD Display. Replace the LCD Display. Make sure iPhone is OFF when you replace it, or you will damage the LCD Display, or the logic board.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you, I just ordered one, I'll post back after I've installed it.
por
hi there have a customer with the same problem and is leaving phone off later im going to try a lcd from a working 3gs see if that cures it il update my progress
Pontuação 0
2 comentários:
Great, Thanks.
por
Any updates ?
por
Just an update changed the lcd and phone is working 100%
Pontuação 0
Adicionar a sua resposta
CreativeMagic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 156
