Ir para o conteúdo principal
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Perguntas Visualizar todos
circular dots flashing around the timed area
I suddenly have flashing dots going around the area where it shows how much time is left for drying. Is this something I should be concerned about?
. 45 .
Similar to the above and dots move in a circle.
The dryer is working properly.
Please let me know.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
What does it mean if it’s doing that same thing on my Samsung washer
por
Did you ever figure out what it is for a washer?
por
Adicionar um comentário
2 respostas
Solução escolhida
This is true for a Samsung dryer and may work for you:
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Esta resposta foi útil?
Pontuação 10
8 comentários:
Thanks for taking the time to provide a response. That was definitely our issue and your answer helped us fell better. Have a good one.
por
Wow! Thanks so much for this much needed advice. We had the same question and happen to also have a Samsung dryer and that is exactly what it was. Thank you for posting that answer which saved us a lot of time and headache:)
por
Thank you! I had the same problem and thought oh no! Do I need to call a repairman? This was indeed the problem. It must have been pushed by accident and we didn’t even realize it.
por
Thank you!!!
por
Thank you for your response! This was the case for my Samsung dryer as we recently started using the Wrinkle free option! Glad to know that dryer is working ok. :)
por
Exibir mais 3 comentários
This isn't true for my fridgidare . I cleaned the ducts inside and out and it still shows the dang dots???? Help pls
Pontuação 0
Adicionar a sua resposta
debbie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 21
Últimos 7 dias: 100
Últimos 30 dias: 553
Duração total: 45,297
