Ir para o conteúdo principal
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 Perguntas Visualizar todos
Pergunta encerrada
My Galaxy tab 3: I inserted micro SD.
My Galaxy tab 3: i inserted micro SD. the device appeared on the storage memory, but the galaxy tab dent use it for storage . it keep saying no enough memory???
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
The galaxy tab thinks that an inserted SD card is for media storage alone, none of your apps will transfer to there. In short, and SD card is only for the device to use and not the user.
If this helps, don't forget to mark this answer as Accepted!
Esta resposta foi útil?
Pontuação 0
My samsung tab3 says my sd card is unmounted I dont know why
Pontuação 0
1 comentário:
I've got the same problem and can't find a solution either.
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 1,568
