Ir para o conteúdo principal
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
my screen has got diagonal pixellated patterns
The screen on my iMac has stopped working and I do not get an Apple logo unless I start it up in safe mode. If I do it has diagonal pixellated patterns which make it impossible to see anything. In normal start up mode there is just a strange pattern and the pointer becomes some lines of text.
I am told that it must be the logic board. Is it possible to get a replacement? Does anyone know where?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I have a problem with my Mac Screen. There appears some lines on the screen. What can i do ?
is it reparable? or should i change it?
por
Adicionar um comentário
4 respostas
Pergunta mais útil
While I agree with matthewfrey, he doesn't actually answer the question:
Buy a new logic board
Esta resposta foi útil?
Pontuação 2
I would agree, I have seen many fail in the same way, poor quality graphics chips that are part of the logic board. for the cost of a new logic board, you are half way to a New iMac, and given the age of the machine, it may be time.
Pontuação 1
Which is the best way that i can work with it better........?
I hope i will get a solution..
with thtnks.
Pontuação 0
2 comentários:
Please cut and paste this into a new question so it will receive the attention it should. Thanks
por
where can i add new questions ?
por
Pontuação 0
Adicionar a sua resposta
Roger será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 3,401
