Ir para o conteúdo principal
7.9 inch display / Model A1455 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
30 Perguntas Visualizar todos
Missing Surface Mount Component
Hi,
I've had an iPad mini come to me which has been dropped and a complaint that the replacement digitizer doesn't work.
On inspection, there seems to be a missing surface mount component which has been dislodged and mislaid.
Can anyone identify the component?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
that is normal--those solder pads are placeholders and do not hold a component.
If it is an aftermarket digitizer presoldered assembly, the aftermarket touchscreen ic would be my first suspect.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Simon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 182
