Ir para o conteúdo principal
The economical version of the Samsung Galaxy S4, released in July 2013.
99 Perguntas Visualizar todos
WIFI Problem, not good reception!
Where Do I do find the wifi antenna? wifi works but i nedd to be very very close to the router to get signal. if not it is so lame!
Esta é uma boa pergunta?
Pontuação 10
1 comentário
Is slow cut off and on some kind of ring circle is rotating all the time
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Hi again!! I got a smashed s4 in ebay. I tried to detach the bottom wifi connector. Signal went just a little worse. About the same. I saw in the link above that the antenna is in the bottom back part. I perhaps think it was faulty. Maybe moist, dirt, water or??? Anyway i clicked both backcovers off and switched them. NOW WIFI IS FINE!! PERFECT LIKE ALL MY ITHER PHONES!!. SO IT HAS TO DO WITH THE ANTENNA I SIDE THE BACKCOVER BOTTOM. Regards lis
Esta resposta foi útil?
Pontuação 1
Hello, I had similar problem - Wi-fi kept dropping out.
However, by lucky chance, I have found what was causing it - for some reason, S4mini can't handle both Wi-Fi and BT on. Or to be precise: If you start Wi-Fi and THEN BT, it'll work till first sleep mode.
...and since I'm wearing MiBand for notifications, BT was always on in my case...
Pontuação 1
Here is a good tutorial "How to Fix the WIFI Problems for Samsung Galaxy Smartphone" for your reference http://www.etradesupply.com/blog/fix-wif...
Pontuação 0
Hi there.. did you find a solution?? I got several s4 and s3 to test my router and router is NOT the cause! There's something wrong in the hardware. All other phones report fine wifi (rssi) from 10 meters from router. My faulty s4 can only connect from 2.5 meters from router. Any further away it pops out. As I say I have multiple phone to test with. I got the phone tester app. Select wifi and stuff. Here it tells you the rssi dam value. This is an error I the hardware as I have had this problem with THIS phone from day one. Please respond if you got some news on this. Thanks Liz, Denmark (lisbethsighfehrmann@gmail.com)
Pontuação 0
My phone won't stay connected to the WiFi that long and then to get back on it takes forever
Pontuação 0
Adicionar a sua resposta
BENITO SANCHEZ será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 26,059
