Why does my iPod show a folder with a warning sign?
My iPod shows a folder with a warning sign and below it the words www.apple.com/support/iPod. What could the problem be and how can it be fixed?
Esta é uma boa pergunta?
normally that would mean that the hard drive of the iPod needs to be replaced - any clicking sounds in the past ?
Esta resposta foi útil?
please click here - expecially the posting that is shown first (you should read the rest too - but this one could be important
since the link i wanted to add is a little bit censored, i can only recommend you a googe search with: "iPod diagnostic mode" <- use it incl. the " - the first result should give you some informations about the diagnostic mode and how to verify your harddrive without the use of a computer
good answer +
Go to www.apple.com/support/iPod like it says.
There are several different warning signs that Apple uses. Please take a look at this link: http://support.apple.com/kb/HT1378
to identify which one you have and the probable fix.
fresh research +
Why do I have a triangle warning that says NO COMMAND?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 2,479
