Will not boot/Black screen
I have a late 2006 white 20" Intel 2.16 iMac that will not boot. LCD stays black and there is no chime during the boot process. The first 2 diagnostic LED's both come on but the 3rd never lights up. I have attempted to hook an external monitor up and still no video is displayed. At this point I have replaced the logic board, the inverter, and the power supply. Any thoughts on where to go from here? Is it the LCD display itself of a possible dead CPU?
Esta é uma boa pergunta?
3 comentários
I replaced the RAM with known working and had the same result. I also went ahead and replaced the processor and still no luck. Would a failed hard drive show this same symptom? I would think I would at least get some sort of video output. Would a dead LCD screen cause this to fail to boot?
por Jason
Can you explain what you did in more detail.All things you have changed.
por skyethespy
You suggest that 1174 iMac's still exist. I will believe it when I see one. Are there fuses in the logic (mother) board in this model. Can you bake it in the oven to fix it?
== Update ==
Memtest is nice. When I used seatools it seemed they verify that a hard drive is working if you can create a folder on it or read the contents of a folder. They go way into details if you have a microsoft based PC. Oh yea update-there is a guy who has two working 1174's at teckwaste recycles in santa ana CA. Am I surprised
por will
