Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
other pepole can`t hear me
i have a problem with microfone, i can`t hear nobody, i already change the dock with microfone complete new and this option don`t help me. I need change something else? where?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
If people can hear you it's not the audio ic chip
I would try another chat hour port it's possible you bought a faulty part.
Try this when you get new part see pic
Actually install it directly without taking the charging port out then insert battery and start up phone the make a call and see if that mic works
It saves you time from taking phone apart if part doesn't work..
I do this with most repairs it saves time if parts faulty
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
If you can't hear them either and they can't hear you there is a problem with you audio ic chip.. Try this
http://m.youtube.com/watch?v=prSZ9yJnofY
Pontuação 1
1 comentário:
i try this think and dont help me,
this is what i do for try fixit:
1 change complete connector dock with new mic
2 follow your advies
the strange is i change all things and still the same, i mean i ear the people btu they can t ear me, if i talk hands free they ear me fine or by viver skype etc, what i need to do more?
por
Definitely start with with Con's link. Also, new dock connectors typically have bad mic's. For whatever reason they have really high failure rates. You should check the return policy.
Pontuação 0
I go try that again like you say, with new part, because I have done at begin, change all dock part inc mic, so I go buy a new item I will try again once thanks I let you know what happens then
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 131
