Ir para o conteúdo principal
Normal CPU tempature at 100% Load
I recently redid the thermal paste, with a very small amount of arctic silver ceramique. I was unable to purify the surface using isopropyl, so I just wiped it down with a non-linting cloth.
With 100% CPU load using Prime 95, the CPU tempature is at 190, and the heatsink is at 155. I never saw it get this hot. The max used to be 186, however that was at 90% CPU Load.
Could it be due to the paste being fresh and not broken in?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
I think you should reclean and reseat everything using fresh thermal paste. These themps are much too high. My MBP runs at max 140 degree with the lid closed.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Zenitar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,445
