Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Why dose screen seem to have white lines appearing in back ground
My screen seems to have faint white lines running top to bottom in the back ground of my screen. On occasion the screen will go black an than come back on its own. When it comes back it still seems to have the white lines? Does anyone know what might be causing this? Thanks for any help.
Esta é uma boa pergunta?
Pontuação 32
6 comentários
Thanks for the replies is it possible that a small fall could dislodge this connection? This is my Daughters phone who works at a Vet. She said when she bent down to pic up a dog her phone fell out of her pocket. so it didn't fall to far and worked fine after that. This problem started about two weeks latter while she was sitting down using her phone.
por
I had two customers with iPhone 5 S same this problem. First one, touch screen was working with white lines and second one , touch screen was not working. Just it needed to replace touch screen chip and I did that and the white lines gone and touch screen start working.
por
my phone fell now i have the white lines at the top and it is really frustrating as the screen no longer responds when i touch it on a regular basis and occasionally works when the back of the phone is hit on my leg but then shorty stops working
por
I dropped my iphone 7s in a pool filled with dry ice. It won't turn on anymore. Please help!!
por
I have an android, never dropped it or banged it on anything. I did download a game and played it for two months they had a few updates after that the lines started on my phone. I did erase the game and all content of it. Same problem, an ideas?
por
Exibir mais 1 comentário
Adicionar um comentário
34 respostas
Pergunta mais útil
Esta resposta foi útil?
Pontuação 5
6 comentários:
That happens to me to I don't now why if I didn't drop my phone and the white lines are there I tried to turn it of or make your phone die but I couldn't.
por
when you say touch screen chip do y ou mean the touch screen or the chip on the logic board?
por
what chip?????????
por
Touch screen IC on logic board
por
how much is it
por
I dropped mine in water but last night the lines weren't there, when I woke up this morning they appeared and they won't go away. I can still touch my phone and everything works right except the lines. They blink in and out sometimes, I've reset my phone, taken the screen off and put it in rice but, the lines won't go away, do I need to go get my screen replaced or what exactly do I need to do?
Pontuação 4
2 comentários:
Hey did you ever figure out this issue? I dropped the top half (from earpiece to maybe half way down) of my iPhone 6s into coffee and I immediately dried it and it was fine that day. But today I have faint blur lines, sometimes dense blue lines and then beyond that sometimes a clear screen. Did I damage the lcd or an internal component?
por
What u did now to this phone
por
How can i get a black line out my phone
Pontuação 2
2 comentários:
Might just need to repair it
por
you need to replace the screen, happened to my old phone
por
I went to a cave and I put my phone into a waterproof bag and carried with me.. after some water activities I saw my phone was wet and I quickly grabbed my Samsung galaxy j7 prime from the waterproof bag. I wiped it and started to off it because I was scared if any further problems will happen. Then after that, i back sensor was not really sensitive and I tried so many still cannot... Then when I brought to the shop he said the humidity in the air might turn into water vapour and got into my phone screen.. while I and the shop people were talking my phone screen suddenly turned to white grey vertical line.. Can anyone please help me...
Pontuação 2
Your screen is not seated securely on the logic board, did you have your screen replaced recently? If not then take your iPhone back to Apple for a replacement.
Pontuação 1
4 comentários:
railmanm,
por
But would it cost some money?
por
mine literally just isn't working and im not sure why.. The lines appeared completely out of the blue, but it hasnt been dropped at all recently or in any water damage
por
Horizontal line appears on my phone travel down and disappear. No fall,nothing and only I updated software...Worried, what could be the reason
por
You could try a hard reset or a full restore if it just happened out of the blue..
If it was dropped then it's lcd damage..
But if just happened for no reason then I would get it replaced under warrenty ..
Pontuação 0
2 comentários:
Had this happen one on a iPhone 5 I was repairing I just unclipped the connectors reseeded and worked 100%
por
Con how do you do that that's awesome if you see this. Comment plz answer it I need help and I'll be taking
por
It could be a screen that went bad. But I just purchased a replacement screen and upon installation the screen was black with white lines. I had just about given up but tried one more time to put it on and it worked. I think the LCD connection is very sensitive and if it's not perfect it will display those lines. Just an observation based on personal expirence.
Pontuação 0
I replaced a cracked scrren in my phone (5) not s, and the new ones has very, very faint vertical on it, almost hard to see. Just wondering if there is anything I should check, or something I may be able to reseat or tweak to get rid of them???
Pontuação 0
I left my phone on all night and I got black lines on my scree what do I do ??
Pontuação 0
I don't know what to do
Pontuação 0
There is a line on the screen of my phone what can I do to fix.
Pontuação 0
2 comentários:
Yh I need help to
por
Smash it get new one
por
Why are vertical whir lines go down my screen
Pontuação 0
It's either the LCD going out or it got wet. Had mine in my pocket while walking during a heavy down pour within a hour the white vertical lines appeared.
Pontuação 0
It might have water damage my old phone did it I took it to the phone shop and they said it's got water in the battery there's nothing u can do about it apart from get a new phon
Pontuação 0
1 comentário:
If your phone got wet, take the back off and put it in a big ziplock back with uncooked rice, leave it over night. Should help. Good luck
por
I dropped my Iphone 6 multiple times but nothing broke. Then a week later white lines start appearing and won`t go. My friend said its a virus but I don`t know. I tried restarting it 2 or more times, its doesn`t work
HELP!! ESAP
Pontuação 0
1 comentário:
My brand new phone got white lines around the screen and I haven't dropped it yet or put it on water
por
I want to stop the lines on my phone
Pontuação 0
When it was raining ☔️ I thought it was in my plastic bag and I dropped it and it was still working at first and then it cut off and then It had a bunch of red and white lines and it still works I'm charging it now
Pontuação 0
This is likely to screen connection issue. You need to tear down the phone and properly connect the screen. On an iphone 5, at the top right corner, there should be a metal shield. If you have a toolkit, remove that and firmly press all of the connections. That is my solution.
Pontuação 0
My phone
Fill in a water and i pulled rice and my phone got line
Pontuação 0
1 comentário:
me too in alcohol
por
This is happening to me too it honestly helped when i shut my phone comepletlty off and let it sit over night.
Pontuação 0
I honestly turned my phone off and let it sit.
Pontuação 0
Hi yeah you needn’t to replace the screen and put the thing in together as it may be wonky or you could go to woolich phone shop and he pulls fix it for you
Pontuação 0
Put it in rice fo 24 hours it should be back to normal if that doesnt work take it to ur phone store.
Pontuação 0
I did a re-set. Solved the problem on my iphone
Pontuação 0
1 comentário:
IPhone reset fixed it
por
I have an Android phone, the white lines happened, but I had the phone for 4 years I pushed the amount of gig's alotted for this phone. The bottom line was the screen was going out. Got a new phone, all better. Support always ask if you dropped it or banged it against something, I never did. Sorry If I didn't help.
Pontuação 0
I have an iPhone and a reset fixed this problem with the state lines
Pontuação 0
It happens when digitizer connector is not connected on the motherboard or is faulty. You must disconnect and connect that again to solve this problem.
Pontuação 0
Hello…this is what I'm seeing on my J6 phone screen. What could've caused this and what should I do?
Pontuação 0
Was screen ever replaced, or OEM screen?
Pontuação 0
Mine is too I neeed help
Pontuação 0
What can I do when my Android phone have white lines on it?
Pontuação 0
please help me how to move them
Pontuação 0
1 comentário:
It probably is a backlight issue, you would have to order a new backlight or screen, or have a reputable repair store do it for you.
por
Hiiiii! Same thing happened to me, I dropped my phone, white lines appeared! I left my phone alone without touching it and a lot of them disappeared! I don’t know if they’ll come back, but for now im grateful it was white lines and not colored lines.
Pontuação 0
i dont know i have this problem too :(
Pontuação 0
2 comentários:
when i use alcohol in my phone the white line appeared help me plss :(((((
por
water damage :(
por
Adicionar a sua resposta
railmanm será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 44
Duração total: 213,585
