Ir para o conteúdo principal
Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
286 Perguntas Visualizar todos
No video/audio from wii
I have a wii and have narrowed the problem down to the motherboard. I have no video or audio but it turns on and the disc spins and everything but there is no black screen or anything its like it isnt even connected to the tv and the cords are good cuz I use them with my regular wii all the time? Thanks
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Can you shine a flashlight into the AV ports to see if there is damage? Since you have another Wii, you can compare the ports to see if there is any difference physically
por
Adicionar um comentário
3 respostas
Pergunta mais útil
try replacing the wifi card because in older computers/game consoles if the wifi card fails then the system will not boot, this worked with mine that had the same issue. However if that does not work then it was a NAND failure and the motherboard will have to be replaced.
Esta resposta foi útil?
Pontuação 1
Did you double check the audio plug is in the TV or monitor
Pontuação 0
1 comentário:
What an absolutely amateur answer.
por
Checking the capacitors is a good idea, specifically the 3 or 4 on the video circuit. Before you take it apart leave it connected to the tv and turned on for 5-10 minutes, if you start to see a faint image then those caps are likely the problem. Or try a different tv that displays a no signal error and see if the wii even outputs anything.
Pontuação 0
Adicionar a sua resposta
Nathan Carlson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,186
