Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Perguntas Visualizar todos
Pergunta encerrada
Only sync a few megabytes at a time before dying
I recently replaced my hard drive because of this problem. I narrowed it down to being able to sync for a small amount of data at a time, then disconnect from my computer. If I try to do more it will return write delays on my laptop and reboot and go into "must restore" message. If a let it sit for 30 min and perhaps less without doing anything else, I can reset it to come back up happy, and I can see all of the music I have successfully synced again.
Do you think I still have a hard drive problem, or is it the logic card. Battery status is fine will go down if I leave on and charge up if connected, and appears to have no affect on whether my syncs are successfull or not.
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
I noticed you never got an answer to this. Are you still having this problem?
por
Yes, I had actually given up on checking :) I just ordered a new logic board hopefully that will fix the problem. If not I guess I am collecting parts for future systems :(
Thanks!
por
Adicionar um comentário
1 resposta
If you try reseting the firmware it could solve your problem. If by dying you mean shuting down, it could be a problem with a connecting between the harddrive. It could be a faulty logic board though.
If its running out of power it might need a battery replacement.
Hope this helps!
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 813
