How do I put a lock on my wifi router
I have a Linksys router. all my neighbors steal my wifi. how do I install a locked password
Esta é uma boa pergunta?
Set the encryption to WPA2 AES, nobody can hack that.
Esta resposta foi útil?
how to prevent luck so that no one can huck
i think you just need to reset the router and type 192.168.1.1 and follow the recommended settings and make your own username (SSID) and password and save the settings and restart trhe router more steps and help visit www.linksys.com/support_password.html and i hope this will help to solve the problem and let me know if you have any other question
Login to the router by accessing the webpage myrouter.local or default IP address 192.168.1.1. Now you can change username and password of the router.
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 8,372
3 comentários
Enable Network Encryption. In order to prevent other computers in the area from using your internet connection, you need to encrypt your wireless signals. There are several encryption methods for wireless settings, including WEP, WPA (WPA-Personal), and WPA2 (Wi-Fi Protected Access version 2)
por Lore
i had the same issue its just reset the router and reset with recommended settings visit http://goo.gl/uglBKa . this will help you . thanks and gud luck
por leeschelsea
thanks it was helpful
por Ethan Logan
