Ir para o conteúdo principal
Parte da linha de smartphones Windows Lumia da Nokia. Anunciado em julho de 2013.
Lumia 625 completely dead after digitizer replacement
Hi there,
II replaced a digitizer on a lumia 625 today.
The phone was working fine when it came to me, just had a cracked digitizer.
After the repair, the phone would not power back on. No signs of life whatsoever.
I have a wall charger for USB devices that has LED lights that indicate when the power is going to the device and those LED did not change colour when i connected the Lumia 625.
The computer did not detect the device either.
I put the original (cracked) digitizer back on the phone but still no life.
I have tried all the combinations of keys for soft and hard resets but still no response whatsoever.
Has anyone had any similar problems with the Lumia 625 or any lumia for that matter?
can anyone please shed some light on this for me ?
thanks
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
hey guys, got mine a new flex cable, battery and the charge dock board from ebay, replaced them but the phone cannot even start, or charge. I really cannot dump this phone. i need it working
Any help i will appreciate
por Compartilhar
Adicionar um comentário
3 respostas
The flex cable is damaged then. Need to put in a new flex cable
Esta resposta foi útil?
Pontuação 0
3 comentários:
thanks, which ribbon though ? the digitizer ribbon and the battery ribbon are attached to their respective parts
por Compartilhar
The ribbon that connects the two motherboards and the start and volume buttons. it's glued to the frame and even the smallest of crack can break it.
por Compartilhar
again, thanks for all your help much appreciated.
I will try replace this ribbon, bt could you possibly link me to somewhere that sells it ? I don't really know the technical name for it and I have tried entering "lumia 625 motherboard ribbon" into ebay with no results. So do you know the proper name for it ?
I'm in Ireland BTW
thanks
por Compartilhar
hey plz parcel it to me...iif you there then mail me on vishavjeetrana786@gmail.com
Pontuação 0
Hi it happened to me today tried all what you did but no sign of life
then when i checked under microscope i found one broken capacitor next to headphone jack the top one is broken
its L2004 in schematic
i think it happened when i tried to remove the board out
i don't know from where i can buy this capacitor if anyone knows anything about it plz put some light on it i will appreciate
Pontuação 0
Adicionar a sua resposta
smithbyrne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 5,302
