Ir para o conteúdo principal
Repair guides for the MacBook.
3787 Perguntas Visualizar todos
Pergunta encerrada
Why is the battery not charging?
I have a 2.0 ghz Core 2 Duo (Merom) White Macbook. It refuses to charge the battery now. When plugged in, the Magsafe adapter does not light up at all, but the battery icon changes to Not Charging. I have tried three different adapters with the same results. I have also tried two different known-good batteries (1 Apple OEM and 1 aftermarket) without any improvement.
I can still use the computer with only the power cord. If I remove the battery, the computer continues to function.
If I remove the power cord but leave the battery in, the computer will continue to function. The battery refuses to charge.
Any suggestions? It was charging perfectly overnight and has just stopped charging.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Just wanted to give you an update: I swapped the Magsafe port and board and everything is working fine now. Cheap fix, so if you have this problem try swapping the Magsafe board first.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Download and run Coconut Battery to get a much better idea of the status of your battery, let us know your results:
http://www.coconut-flavour.com
Pontuação 1
1 comentário:
The charge status of the battery is 60%.
The health of the battery is 91%.
It has 4 loadcycles.
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 137
