Ir para o conteúdo principal
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 Perguntas Visualizar todos
Need a good source for taking apart a 23" HD Cinema display
Does anyone have a good source (an Apple service manual would be ideal) of instructions for taking apart a 23" Apple HD Cinema Display (Aluminum)? I've poked around online but haven't found anything great. Thanks!
Esta é uma boa pergunta?
Pontuação 6
1 comentário
I have the Cinema Display take apart. Email me at fedguy2@ pacbell .net
por
Adicionar um comentário
8 respostas
Solução escolhida
Try this link. Ralph
http://docs.google.com/viewer?a=v&q=cach...
Esta resposta foi útil?
Pontuação 3
8 comentários:
Oh my. Any bets on how long that stays online before Apple's legal team has their way with it?
por
I don't think so (or they aren't able to properly use a search engine).
oh, somewhere between the n and the t is one of the search results ;-)
por
On the basis of Kyles remarks the OP should download this material now. Ralph
por
can you reup please?
por
Try this: service
por
Exibir mais 3 comentários
Once inside, check the VR3 3.3VDC REGULATOR center pin to make sure it is putting out 3.3v, bad one will put out about 4vdc. It is very common problem with this 23" aluminum case.
See my pictures here:
http://s807.photobucket.com/albums/yy352...
Pontuação 3
1 comentário:
Hi
I have a blank screen (No Lights or display) I have followed your advice and tested the VR3 Regulator. Center pin is 1.96 DCV and Right pin 5.1. Assuming this show that it is faulty I was wondering the part number i should order and maybe where you were able to source it.
Also being surface mount is there any issues with DIY or would it be worthwhile finding a new board.
Thanks in advance
por
i've found a korean website - but the main focus is "looking inside" and not the "show others how to do it": CLICK
and a disassembling "guide" for the 20" CLICK
Pontuação 2
1 comentário:
The first link is for an acrylic monitor but the one at the bottom is what I need. Thanks.
por
I have the 23 dvi version if you need another manual let me know.
Apple Cinema Display 23" HD DVI Manual
Pontuação 1
1 comentário:
Thank you for the link and pdf!
por
All manuals.
http://tim.id.au/laptops/apple/
Pontuação 1
lokk at this master from Cile he helped me sure //// A1097 Broken Power Adaper fix for a 23" Apple Cinema HD Display. copy and look at Youtube good lycka
Pontuação 0
Does anyone still have this display service source pdf around? I need to take mine apart and can't find the service manual anywhere...
Pontuação 0
Add me to the list of people needing a dissassembly guide. My new-to-me display has mould on the inside of the screen :( Heartbreaking.
Pontuação 0
Adicionar a sua resposta
jasonnrogers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 35,969
