Ir para o conteúdo principal
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Perguntas Visualizar todos
will not boot shuts off
The iMac has a pretty full hardrive. 256 g hard drive with 9 gigs free. It had been freezing up and running slow. Then it started shutting it's self off when I try to boot up. I have tried several times with same results
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Start up from your system installation disk by inserting it and holding down the "C" key. On the second screen the pull down menu will appear. Go to Utilities - Disk Utility and repair your hard drive if you can. If it does boot, then the logic board is OK and you need to look at repairing the system, re-installing the system or if the hard drive is not seen then replacing the hard drive.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ken será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,035
