Blue screen of death
The hard drive won't boot up, but the startup utility does. Is all lost?
Esta é uma boa pergunta?
If you can boot from the startup disk try running Disk Utilities to see if the drive can be repaired. Having a external drive plugged in to save your data wouldn't hurt either. If this doesn't work come back and we'll work on how to replace the drive.
Esta resposta foi útil?
No repair it would appear. I can reformat but lose everything in the deal. I've been told we might firewire the iMac to our MacBook and see if the MacBook recognizes the iMac as an external hard drive. Haven't tried that yet. Thanks for the response!
I would definitely try the firewire target disk mode. I've found that it always works, provided the computer will boot to the point of recognizing the command.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,796
2 comentários
You sure you aren't trying to run Windows on it? :P
por Josh Calvetti
Good one. Recognize the "blue screen of death" as a MS term... but no.
por Doug
