Ir para o conteúdo principal
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
64 Perguntas Visualizar todos
Can the USB 1.1 be changed to the 2.0?
I have 4. 2 ea. 366 & 466.
Thought it may help.
Will the firewire duplicate some of the
USB functions, maybe faster.
Thank you, Leland
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
6 respostas
Solução escolhida
No. There are no logic board upgrades for the Clamshell that have USB 2.0.
Esta resposta foi útil?
Pontuação 5
1 comentário:
Agreed +
por
"In order of speed (lowest first)
USB 1.0 -> USB 1.1 -> FW400 -> USB 2.0 -> FW800"
Not really.
For all practical intents and purposes, FW400 is MUCH faster than USB 2.0, and even faster than USB 3.0 in many instances.
Pontuação 1
This Firewire is FW400 which runs at 400Mbps rather than USB 1.1 which runs at 12Mbps.
If you are connecting an external drive, make sure it has a FW connector.
The hardware does not support USB 2.0. Add a USB 2.0 external hub and it still runs at USB 1.1 at the iBook connector.
1Mbps -> 12Mbps -> 400Mbps -> 480Mbps -> 800Mbps
But in the best tradition of all of these standards, YMMV.
Pontuação 0
Mark,
I guess my point was that FW400 is faster than USB1.1.
I have Macs with USB1.1 and FW ports and I use FW drives. I couldn't be annoyed with the slow speeds of USB1.1.
Pontuação 0
No, you will need to upgrade your logic board to change it to FireWire.
Pontuação 0
ขอบคุณข้อมูลของคุณหัวข้อนี้ช่วยฉันมากเกินไปสำหรับการแก้ปัญหา
ยินดีต้อนรับสู่
<br /> <a href="http://batman999.com/"> สล็อตออนไลน์บนมือถือ </a> <br /> <br />
Pontuação 0
Adicionar a sua resposta
Leland Lang será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 2,679
