Ir para o conteúdo principal
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 Perguntas Visualizar todos
Why is the screen white after repaiedr on/off button
Took mIne apart to fix the on/off button everything was worked perfect before but that. put it back together w/ extreme caution but the screen turns all white w/ noting on it now.
It does connect to I Tunes deletes and add song, plays from it but when I disconnect white screen only and it also does it when I plug the earphone jack aging white screen only
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Try shorting out the battery to the case, if you are still having problems then you will need to replace the LCD.
Esta resposta foi útil?
Pontuação 0
Hi Idive4fsh,
Did the propose solution work?
Thank you,
../Bruno
Pontuação 0
Adicionar a sua resposta
Idive4fsh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 271
